[SOLVED] Designing Automatic Voltage Stabilizers
gccute
Junior Member level 1
delhi
HEY GUYS,
Need help in designing Automatic voltage stabilizer .... what will be the logic behind designing and what type micro controller to be used for this purpose.
need your support please.
Thanks.
Re: Voltage Stabilizer using microcontrollers.
AC or DC stabilizer? i guess you want to designing an AC stabilizer. look at EFY magazines august 2010 on page 64, has voltage stabilizer using 16F877A build by prof. K. Padmanabhan, S. Ananthi and Narayana Kumar. its a static voltage regulator, not a servo.
Are you using analog or digital ,or Micro-controller ?
Use comparator (LM324) its simple
please specify your needs i can help you .
i hope gccute need & also i have need Design of single phase stabilizers transformer. its as
1_ i\p 90 volt to 290 & o\p 200 volt to 240 volt.
2_i\p 140 volt to 440 & o\p 200 volt to 240 volt.
Ok What is accuracy?
but which type circuit you need analog .digital or microcontroller ?
as pasibal pic 16f676 or 16f72 ?
hi
Can you please share the circuit of a AC stabilizer using LM324
hey guys,
need help in designing automatic voltage stabilizer .... What will be the logic behind designing and what type micro controller to be used for this purpose.
Need your support please.
Thanks.
try this circuit diagram
Thanks Irfan, I am going to make this circuit on proteus and check the operation if you can send me the controller program,
I have another circuit which I want you to confirm the IC's numbers I think they use 16F876A and LM324, Please check and confirm.
One more thing let me know the operation of relay it will operate one by one as per variation of voltage
Thanks again
try this hex file
  • 100V stabalizer 4-11-12.rar
Thanks Irfan, its really great help. Would you please let me know the switch of relays on voltage variations.
Please
Can u plz help me with lm324 stabilizer circuit ?
I am send the diagram of my auto transformer, Can you please let me help on relay wiring
pls see the attachment
Please find the attachment
try this hex file
hi, this hex file is not working properly.
I checked it, in real time simulation.
I think you write this code with CCS compiler.
Only timer,over and under voltage section is ok.
And stabilizing section is not working.
All 3 relays become off at same time, when adc volts are 1.6v.
And become on together, again at 2.45v.
Over voltage occurs at 2.55v.
Over voltage restores at 2.40v.
Reactions: tpetar
    tpetar
TRY THESE .
1) Follow the diagram properly (transformer tapping must be same as diagram ).
2) Give 220v to stabilizer and Tune variable and to set output same as input.
3) use variable transformer to check it .
Of course, at that time all 3 stabilizing relays should on (energized).
Can you measure dc volts on pin 13, when output and input is same 220v ac.
