#include <p89v51rx2.h>
#define HIGH 1
#define LOW 0
sbit data_bit=P3^3;
sbit clk=P3^2;
void MSDelay(unsigned char delay)
unsigned char i;
for(i=0;i<delay;i++)
void ps2_write(unsigned char command)
unsigned char i;
unsigned char parity = 1;
data_bit=HIGH;
clk=HIGH;
MSDelay(100);
clk=LOW;
MSDelay(100);
data_bit=LOW;
MSDelay(10);
clk=HIGH;
/* wait for device to take control of clock */
while (clk==HIGH); // this loop intentionally left blank
for (i=0; i < 8; i++)
if (command & 0x01)
data_bit=HIGH;
}else
data_bit=LOW;
// wait for clock
while (clk== LOW);
while (clk== HIGH);
parity = parity ^ (command & 0x01);
command = command >> 1;
// parity bit
if (parity)
data_bit=HIGH;
}else
data_bit=LOW;
//clock cycle - like ack.
while(clk==LOW);
while(clk==HIGH);
data_bit=HIGH;
MSDelay(10);
while (clk==HIGH);
// mode switch
while ((clk==LOW)||(data_bit== LOW));
// hold up incoming data
clk=LOW;
unsigned char ps2_read()
unsigned char data1 = 0x00;
unsigned char i;
unsigned char bit1 = 0x01;
// start clock
clk=HIGH;
data_bit=HIGH;
MSDelay(10);
while (clk == HIGH);
while (clk==LOW);//eat start bit
while (clk==HIGH);
if(data_bit==HIGH)
data1 = data1 | bit1;
while (clk == LOW);
bit1= bit1<< 1;
// eat parity bit, ignore it.
while (clk==HIGH);
while (clk==LOW);
// eat stop bit
while (clk==HIGH);
while (clk==LOW);
clk=LOW; // hold incoming data
return data1;
void serial_init()
FCF=1;
SCON = 0x50; /* mode 1, 8-bit uart, enable receiver */
TMOD = 0x20; /* timer 1, mode 2, 8-bit reload */
TH1 = 253; /* reload value for 2400 baud */
ET0 = 0; /* we don't want this timer to make interrupts */
TR1 = 1; /* start the timer */
ES = 0; /* allow serial interrupts */
EA = 0; /* enable interrupts */
void main()
unsigned char count=0;
serial_init();
P2=0x00;
ps2_write(0xff);
while(count!=3)
SBUF=ps2_read();
while(TI==0);
TI=0;
count++;
ps2_write(0xf4);
while(1)
ps2_read();
while(TI==0);
TI=0;
count++;
yes I want to make pc keyboard.
Any one knows How to find which key is press from keyboard on hyper terminal?? Like When I check my program on hyper terminal its shows the output only A B C D keys only what abt other keys?plz help me...
