jeevan.akula
Newbie level 6
I have few questions on physical design plz any one ans to these questions?
I am new to physical design .. i have some questions here plz any one ans to these questions..?
1) How we will decide aspect ratio, with an example?
2) How to calculate core area?
3) How periphery area is decided ...?
4) Is that key board margin should equal on the four sides of core area?
5) To set up the data what are input and outputs ?
6) Is def only the file as input to CTS stage? what is the output file? As well as for routing and chip finishing stage?
7) Why we are using SPICES instead of verilog netlist for LVS check?
8) what it exactly specifies align bus signal pins b/w macros ?
9) What are the power network constraints? How it helps to reduce the IR drop analysis ?
10) What are black boxes ?
Thanks in advance .....
Regards,
Jeevan
Regards,
Jeevan
