elt42at
Newbie level 6
HELLO TO EVERYONE!
I tried to use, BUS POWERED USB to UART with FT232RL. The design is so simple but, MY 3.3V output is over 4.2V. So, i re-solder 3V3 and VCCIO pins from PCB. I measured with AVO meter. The LDO output pin (3V3) is 3,26V. IT is OK! But THE VCCIO pin seems 4.4V!!!!!!
I soldered 3V3 pin to PCB, The VCC which goings to MCU VCC is about 3.3V. IT is ok!
Now, I have to solder the VCCIO pin to use FTDI FT232RL UART module in LVTTL 3.3V. I have to use VCCIO pin
I don't understand that, WHY an input (power input pin) makes the LDO output up to 4.2volt ????
I only use FT232RL pins RX,TX,CTS,RTS and CBUS0 and CBUS1 as RX/TX leds and CBUS2 as MCU reset, and CBUS3 MCU interrupt!!!
Please help me about that! I can't get integrated 3V3 output in the voltage 3.3V when i solder the VCCIO pin. It goings to 4.2V. Free un-soldered VCCIO pin seems over 4.4V. But it is an input pin !!!!
Thanks for your answers!
