jpglotzer
Newbie level 5
Hi, I'm trying to implement a bubble sort algorithm in Verilog. Essentially, i have 20 numbers in my RAM, and i need to sort them from lowest to highest. The method is by comparing the 1st and 2nd number, and switching them if the 1st is bigger than second. The same is done for 2nd and 3rd, 3rd and 4th until the highest number is at the end. This is repeated till the 2nd largest number is at the 2nd last position etc etc until it's fully sorted. I'm using a state machine, and i keep getting an error: "can't resolve multiple constant drivers for net", and this shows up for almost all my variables. I have no idea what to do, so any help would be much appreciated! thanks! The code is below:
module question3(clock,start,q_a,q_b,wren,state);
input clock; //declare clock
input start; //start button
output [7:0] q_a,q_b;
parameter [2:0] IDLE=3'b000, ADDRESSES=3'b001, READ=3'b010, COMPARE=3'b011, WRITE=3'b100;
reg [7:0] next_j=8'd0, j=8'd0, data_a=8'd0, data_b=8'd0, next_max=8'd18, max=8'd18, next_counter=8'd0,counter=8'd0;
output reg [2:0] state=IDLE;
output reg wren=1'b0;
reg [2:0] next_state;
always @(posedge clock or start)
begin
if (!start)
begin
next_state<=IDLE;
end
else
begin
j<=next_j;
counter<=next_counter;
max<=next_max;
state<=next_state;
end
end
ram_2port ram1(j,j+8'd1,clock,data_a,data_b,wren,wren,q_a,q_b); //instantiate RAM
always @(state or j or max or counter or q_a or q_b or data_a or data_b)
begin
case (state)
IDLE: begin
j=8'd0;
max=8'd18;
counter=8'd0;
next_state=READ;
end
ADDRESSES: if (j==max)
begin
next_max=max-8'd1;
j=8'd0;
counter=8'd0;
next_state=READ;
end
else
begin
next_j=j+8'd1;
next_state=READ;
end
READ: begin
wren=1'b0;
next_state=COMPARE;
end
COMPARE: if (q_a > q_b)
begin
next_state=WRITE;
end
else
begin
if (counter==max)
begin
next_state=IDLE;
end
next_counter=counter+8'd1;
next_state=ADDRESSES;
end
WRITE: begin
data_a=q_b;
data_b=q_a;
counter=8'd0;
wren=1'b1;
end
endcase
end
endmodule
begin
if (!start)
begin
next_state<=IDLE;
end
else
begin
j<=next_j;
max<=next_max;
state<=next_state;
end
end
begin
case (state)
IDLE: begin
j=8'd0;
max=8'd18;
counter=8'd0;
next_state=READ;
end
begin
next_max=max-8'd1;
j=8'd0;
counter=8'd0;
next_state=READ;
end
else
begin
next_j=j+8'd1;
next_state=READ;
end
READ: begin
wren=1'b0;
next_state=COMPARE;
end
begin
next_state=WRITE;
end
else
begin
if (counter==max)
begin
next_state=IDLE;
end
end
WRITE: begin
data_a=q_b;
data_b=q_a;
counter=8'd0;
wren=1'b1;
end
endcase
end
endmodule
