Half-bridge MMA inverter with pwm.
DeepOne
Advanced Member level 2
45N39E, Russia
So, this is it.
schematics
pcb
test
signal from IGBT gate, without power on collector, 5V/5mks/cell
transformer, primary coil
lower side rectifier
capacitors
upper side rectifier, quad of BR1010 and start module withBTA41
partly collected
ventilator under main transformer
signal from second coil of main transformer
testing - incinerated two electrodes 3мм
Or possible do else on such scheme:
But it is necessary to make sure that minimum duration of the pulse it is enough for feeding upper shoulder of IR2110.
