sum of two squares????
smslca
Member level 1
Member level 1
If an Even number could be expressed in the form a² + b² . And if there exits two other numbers m,n such that
a² + b² = m² + n²
then , my question is
is there any relation between (a,b) and (m,n) apart from a² + b² = m² + n² ??
can you prove that the above equation holds good for any set of numbers...
I did not say for any given (a,b) there surely exits (m,n)
I said " If " p is even and " if " p = a^2 + b^2 = m^2 + n^2 , then what is the relation between a,b,m,n other than p = a^2 + b^2 = m^2 + n^2 equation.
smslca,
Yes...There are a trigonometric relationship :
You can convert that variables to polar coordinates.
smslca,
That's somewhat new and interesting to me
The question has sense only if you specify that a, b, m, and n are all integers. Otherwise, the problem is trivial; there is an infinity of solutions for every even p.
Regards
Z
