at89c52 and lcd interfacing
gnoble29
Member level 1
Member level 1
india
i have an at89c52 and a 16*2 lcd display. how i connect my lcd to 89c52 to disply the message welcome...
if any one know the source code,plz post...
thanks in advance
#include <reg52.h>
#include <math.h>
void lcdcmd (unsigned char);
void lcddata (unsigned char);
void msdelay (unsigned int);
void LCD_sendstring(unsigned char * );
sfr ldata =0x90;
sbit rs=P3^7;
sbit rw=P3^6;
sbit en=P3^5;
sbit g=P2^7;
void main(void)
lcdcmd (0x3;
msdelay (100);
lcdcmd (0x0C);
msdelay (100);
LCD_sendstring("16x2 LCD");
msdelay(1000)
lcdcmd (0x01);
msdelay(5);
void lcdcmd (unsigned char value)
ldata=value;
rs=0;
rw=0;
en=1;
msdelay (10);
en=0;
void lcddata (unsigned char value)
ldata=value;
rs=1;
rw=0;
en=1;
msdelay (10);
en=0;
void msdelay (unsigned int itime)
unsigned int i,j;
for (i=0;i<itime;i++)
for (j=0;j<1275;j++);
void LCD_sendstring(unsigned char *value)
while(*value)
lcddata(*value++);
when compiling on keil i have got the following error messages..what will i do??
This error is because you copied the code to an asm file( i.e. *.a51). Make a new file with extension *.C then copy the code there. Then it would work perfectly.
thanks lot:-D
---------- Post added at 16:58 ---------- Previous post was at 16:53 ----------
which model of lcd display should i select in proteus for simulating the above code....i have proteus6 professional...it provides varity of 16*2 lcd display
to which pin of 8052 should i connect db0.db1........db7 pins of lcd
Go for
LM016L 16x2
---------- Post added at 21:35 ---------- Previous post was at 21:34 ----------
Connect to any port.
---------- Post added at 21:36 ---------- Previous post was at 21:35 ----------
I have highlighted the LCD in proteus
thanks a lot...i succeded in lcd display.it is my first proteus simulation..thanks
---------- Post added at 17:32 ---------- Previous post was at 17:29 ----------
In this program,the display will blinks after some delay....what modifiacation should made to make the output displas the same thing at everytime..that means no blinks....
yes..i need the display premanently still...
