[SOLVED] help me in programming :) detecting the input LOW bits..
romel_emperado
Advanced Member level 2
philippines
guys, do you have any hint on how to program this?
this is the problem.
example if i have input in POR1 = 1111 1010
i need to know which bit is low. as seen in the example there are two low/0 values in the input... how to detect that??
actually from the example P1.0 and P1.2 are low.
i can do that using switch case but i think there is another method to do that. imagine that is 8bits i cant manage to put all that case combination by using switch case from 0 - 255. :sad:
hi raco, what do you mean by bit is set and bit is clear?
how does it actually work?
as i understand it is scanning from P1.0 to P1.7
but i dont actually get the application of bit is set? its my first time to know about that :sad:
im thinking to output the data to another port.. let say if i detected that P1.0 is low then it will output as 1 then if the last bit(P1.7) is low the output is 8..
Bit set and clear is another term for saying that bit is 1 and 0, respectively.
It becomes even easier if you want to output to another port, simply output the value of "i" when you detect a high bit.
for(i = 0; i<8; i++)
if(POR1 & (0x01 << i))
PORTX = i + 1;
i dont realy get it.. i tried it using proteus but it only counts 1 to 8 ;(
this line if(P1 & (0x01 << i)) dont take it's effect
Delay_ms(2000);
P3 = i + 1;
so probably you could try,
for(i=1; i<256; i= i*2)
if(P1 & i)
P3 = i;
But logically, they both should work fine and are same.
PORTX = i + 1;
If you want to set the bit of the other port then PORTX = i + 1; will not do much, it can only take values from 1 to 8.
If you want to set or clear the bits of the other port then you should use
Code C - [expand]
        PORTX |= (1<<i); // set bit
    else
        PORTX &= ~(1<<i);   // clear bit
but if you just want to copy a port to another port then why not use PORY=PORX;
Alex
Both of the replies from raco_rage's posts are spot on and totally correct. However, if I may add, romel_emperado mentioned that he wants to output a numerical value everytime he encounters a low bit. The following code (actually 99.99% replica of raco_rage's code) should work. If not, then I believe the problem should be somewhere else in the code.
if(!(POR1 & (0x01 << i))) // TRUE for bit = 0
PORTX = i + 1;
(Note: Are you sure you want to output an integer to the port at ever occurence of a corresponding low bit? Normally, one would have to bitmask a byte on to a port.....)
yes i that exactly i want to do. i need to detect what pins of P1 is low or high.....
guys, thanks for your help.. i will try your suggestions...
yea, exactly as Klen says, there should be a ! for low.
As the OP says that he wants to output values only from 1 to 8, corresponding to each bit position, he wouldn't need a output value more than 8 unless he is checking a 16 or 32 bit number.
I'm still not clear what exactly you are trying to do,
do you want to have
input out
00000001 -> 00000001
00000010 -> 00000010
00000100 -> 00000011
00001000 -> 00000100
00010000 -> 00000101
please give an example of the input and output you expect.
Alex
example if i have this input:
P1 = 1011 1110
i must know that the two zeros in P1 are located in PIN1 of port1 and the other zero is in port7 of port1... that's what i want to do.. i dont have idea how to do that.. ;(
P1 = 1011 1110
The easiest way I can think of right now is to light some LEDs in active low logic. The code is already provided so it shouldnt be difficult :)
do u mean you want,
P3 = ~P1 ??
nope.. sorry for causing you trouble guys..
this is the problem.. my port1 is monitoring for possibe input.. port1 has 8bits and then for example if P1 detected a value of 253. 253 in binary is 1111 1101
now, i want to know which PIN is low.... obviously if we look at the example input the low bit is in P1.1. let say for example i want to display like this "the zero value of 253 is located at P1.1" :)
something like that guys..
here is an example code i am using but it's not perfect it cant detect the whole 8bits..
Code C - [expand]
8
9
int x = 10100101;
// First bit
(x >> 0) % 2; // 1 is detected that it is in  P1.0
// Second bit
(x >> 1) % 2; // 0 is detected that it is in  P1.1
// Third bit
(x >> 2) % 2; // 1 is detected that it is in  P1.2
etc.
There are some useful defines that you can use , just put them in the start of your code and you can use them after that
Code C - [expand]
#define SETBIT(ADDRESS,BIT) (ADDRESS |= (1<<BIT))
#define CLEARBIT(ADDRESS,BIT) (ADDRESS &= ~(1<<BIT))
#define FLIPBIT(ADDRESS,BIT) (ADDRESS ^= (1<<BIT))
#define CHECKBIT(ADDRESS,BIT) (ADDRESS & (1<<BIT))
#define WRITEBIT(RADDRESS,RBIT,WADDRESS,WBIT) (CHECKBIT(RADDRESS,RBIT) ? SETBIT(WADDRESS,WBIT) : CLEARBIT(WADDRESS,WBIT))
To use them
Code C - [expand]
8
9
10
11
SETBIT(PORTX,2);  // set bit2 of portx (set to 1)
SETBIT(PORTY,0);  // set bit0 of porty
CLEARBIT(PORTX,5); // clear bit5 of portx (set to 0)
FLIPBIT(PORTX,2);  // invert bit2 of portX, if it was 1 it becomes 0, and if 0 becomes 1
                    // example for portx 0x10101010 the result is 0x10101110
if (CHECKBIT(PORTX,4)) {} else {} // result is true if bit4 of portx is 1, false if it is 0
WRITEBIT(PORTX,0,PORTY,2);   // copy the bit0 of portx to bit2 of porty
Alex
hi alexan_e,
thanks for that.. i will surely try that...
---------- Post added at 16:54 ---------- Previous post was at 16:48 ----------
thanks alexan_e, :)
it solves my problem.. excellent!!! :-D:-D:-D:-D
this is my code actually
Code C (Mac) - [expand]
void main()
  SETBIT(P1,2);
  P3 = SETBIT(P1,0);
---------- Post added at 16:59 ---------- Previous post was at 16:54 ----------
to all of your.. thank you so much and sorry for causing your trouble :)
SETBIT(P1,2); sets P1 bit2 to 1
SETBIT(P1,0); sets P1 bit0 to 1 and copies the result byte to P3, is this what you want?
Alex
even if he was able to solve the problem, I am still not clear what he really wanted?
Alex
yes that's really what i want.. i million thanks to you :)
actually the logic behind this solves my problem
---------- Post added at 17:17 ---------- Previous post was at 17:09 ----------
oops sorry raco_rage , actually its not totally solved. im thinking of another but alexan_e give me idea..
its hard to explain how i solve my problem due to trial and error... hehe Im new to programming and Im learning just myself relying on some tut found in google.. :) thanks for helping guys :)
