proteus7 debugging error
prati
Newbie level 3
Newbie level 3
i hav added MT8870 in proteus7 bt there is error while debugging.. "no model specified for MT8870" plzzzz help...
yup.. :| i knw hw2 add new component bt simulator models for certain components such as LM358 n MT8870 r nt available in proteus... we need 2 add lib files .mod files... i came2 knw abt all dese things jst now bt didnt get how to get these spice models i m searchin fr dem if ny1 culd help plzz do...
There is a check box in the device selection screen , below the search entry,
you can check to shown only devices with simulation models so that you are sure that all available devices have simulation models.
This may not be very helpful when you want a specific component but it will help when you need a NPN transistor for example
so that you can select one that you will able to simulate.
Don't forget to uncheck this when you want to add a component like a pin header because it will not be shown.
Alex
Reactions: prati
    prati
@ alexan_e .. hmm thnx..
bt i nid solution fr specific components ..:sad:
Hi. You need the DLL Model for MT8870.lib (MT8870.dll) put this DLL into Models Folder of PROTEUS VSM ;)
