[SOLVED] some problem to my 16x2 LCD (second row always black)
vinodstanur
Advanced Member level 3
Kerala (INDIA)
vinodstanur.blogspot.com
i bought a new 16X2 LCD (JHD 162A) .I connected it as follows.
VCC=5V
VSS=0V
VEE=0V
DATA NOT CONNECTED
RS NOT CONNECTED
R/W =0V
E NOT CONNECTED
LED CONNECTED
BUT, NOW WHEN I SWITCH ON THE 5V power supply, then the 2nd row displays all black!
and i then connected it to a pic16f877a with a "hello world" program...but still no change!!
what should i do now?:cry:
There is a possibility that the LCD is bad. You can try with disconnecting the RW and VEE pins.
Hope this helps you.
if you just connect 1 ,3 to gnd and 2 to positive same result will come did you try
did you try in proteus same circuit
fake Chinese part is our headache
thanks for the information...actually i thought it was the second row because there it written JHD 162A. At first i concluded my LCD was bad...now i will check my code ...
try to program first. easier to just use a working example to check whether the LCD is broken or not. assuming u are going to ground the R/W, make sure the example program is also configured for that.
MY PROGRAM: WORKING IN OSHONSOFT EMULATOR.
#include <htc.h>
#define _XTAL_FREQ 4e6 // 4MHz
__CONFIG(0x3F3A);
#define RS RD0
#define RW RD1
#define EN RD2
void display(unsigned char c)
RS=1;
PORTB=c;EN=1;EN=0;
__delay_us(200);
void init()
PORTB=0;PORTD=0;TRISD=0;TRISB=0;
command(0x30);
command(0x30);
command(0x30);
command(0x38 ); //8) is a smiley, so i had given a space here)//
command(0x08 ); //8) is a smiley, so i had given a space here)//
command(0x01);
command(0x06);
command(0x0C);
__delay_ms(20);
void command(int k)
RS=0;
PORTB=k;EN=1;EN=0;
__delay_ms(15);
void message(const char *s)
while(*s)
display(*s++);
void main()
{ __delay_ms(200);
init();
while(1)
message("hello world");
while(1){};
BUT STILL SAME PROBLEM!!
it is not a serious problem..i was having this but in my board there was a regulator that makes thoes boxes light and dark to show the display clearly.......if you can figure out the regulator then it will be great...and i hope so that it will work....
---------- Post added at 23:37 ---------- Previous post was at 23:33 ----------
#include <htc.h>
__CONFIG(0x3F3A);
#define RS RD0
#define RW RD1
#define EN RD2
RS=1;
PORTB=c;EN=1;EN=0;
__delay_us(200);
void init()
command(0x30);
command(0x30);
command(0x30);
command(0x01);
command(0x06);
command(0x0C);
__delay_ms(20);
void command(int k)
RS=0;
PORTB=k;EN=1;EN=0;
__delay_ms(15);
while(*s)
display(*s++);
void main()
{ __delay_ms(200);
init();
while(1)
while(1){};
try to use this code it is built in code in mikro c compiler and this ode will run in 4 bit mode..i was having the same problem but it figured out...
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
char txt1[] = "mikroElektronika";
char txt2[] = "EasyPIC5";
char txt3[] = "Lcd4bit";
char txt4[] = "example";
char i;                              // Loop variable
void Move_Delay() {                  // Function used for text moving
  Delay_ms(500);                     // You can change the moving speed here
void main(){
  TRISB = 0;
  PORTB = 0xFF;
  TRISB = 0xff;
  ANSEL  = 0;                        // Configure AN pins as digital I/O
  ANSELH = 0;
  Lcd_Init();                        // Initialize LCD
  Lcd_Cmd(_LCD_CLEAR);                // Clear display
  Lcd_Cmd(_LCD_CURSOR_OFF);           // Cursor off
  Lcd_Out(1,6,txt3);                 // Write text in first row
  Lcd_Out(2,6,txt4);                 // Write text in second row
  Delay_ms(2000);
  Lcd_Out(1,1,txt1);                 // Write text in first row
  Lcd_Out(2,5,txt2);                 // Write text in second row
  Delay_ms(2000);
  // Moving text
  for(i=0; i<4; i++) {               // Move text to the right 4 times
    Lcd_Cmd(_LCD_SHIFT_RIGHT);
    Move_Delay();
  while(1) {                         // Endless loop
    for(i=0; i<8; i++) {             // Move text to the left 7 times
      Lcd_Cmd(_LCD_SHIFT_LEFT);
      Move_Delay();
    for(i=0; i<8; i++) {             // Move text to the right 7 times
      Move_Delay();
SUCCESS!!!!! I used my micro C sample program...its working ! So what may be the problem in my program?
the problem is you were using the delay_ms(200) which means delay 200 milli seconds...which a normal eye can not even see it when you use it on the hardware...and the delay_ms(15) also...ans as lockman said there is problem in confguring the bits of the lcd u didnt defined the data ports of the lcd...how can the display should be shown......
