hi,
Well then its not a big deal. you can easily design an omnidirectional UWB antenna which covers the entire UWB frequency range from 3.1-10.6 GHz. For example you can have a look at Circular patch antennas,Bow-tie antennas,circular fractal monopole antenna,quasi-selfcomplimentary-UWB antenna etc....all these antennnas are UWB omnidirectional antennas.
They have simple Geometry and very easy to build and simulate in HFSS.
/SC
how about designing an uwb antenna in lower frequency range (UHF range), is it as easy as designing in 3.1-10.6 Ghz?
Freuency range of ultra wide band antenna is 3.1 to 10.6GHz.
do you have some hfss simulation for that antenna?? or any paper for reference?no this range is UWB at UHF band
this software calculate LPDA antenna for u and you and simulated in hfss after calculate with this software
