[20 pts] [urgent ] Boolean equation simplification
AdvaRes
At home
Hi all,
In my design the datapath delay let me use only frequencies below 1 Ghz.
The logic of the datapath is given by the relation shown in the figure. I need to simplify this relation as possible in order to reduce the delay introduced by the datapath so I can rise in frequency.
Is the relation provided simplifiable ?
treehugger said:
Thanks.
Unfortunately your reply is wrong. In fact when a=1 my relation gives b+/bc your relation gives c+b.
I think: c+ab
your minterms are {1,3,5,6,7} you can K-map it or Quine mcCluskey you get the simplified form above.
Resulting into:
1 AND
1 OR
your concern when a = 1; your orig equation becomes b+/bc is actually equal to b + c when you take the minterms.
A quick check for the orig and simplified form if they are the same is plug in all possible values of a, b and c; you will get the same result;
if you want to implement it via NAND or NOR gates, you may not get a simplified form.
Thanks,
    AdvaRes
Thanks my friend.
I found by K-Map that you're right !
Have you materials abouts Quine mcCluskey technique ?
Only using Nands seems quicker since an AND normally is an NAND and an invertor.
/(/C*/(AB))
so NAND[inv(C),NAND(A,B)]
    AdvaRes
/(/C*/(AB))
Nice idea ! Using Nand and NOR introduce less delay.
4 All :
I gave you each 7 points. Many thanks.
Hello AdvaRes:
Here's a link to Quine McCluskey https://en.wikipedia.org/wiki/Quine_McCluskey
It is usually useful if you have more than 4 inputs of your combinatorial logic circuit. Since your app is just 3- inputs, K-map method should be fine.
The link also has some links of automated (software) for Quine McCluskey which makes life easier. :-D
Draw a Karnaugh map and the result is:
ab+c
