analog_fever
Junior Member level 3
two stage op amp design
I am a novice analog designer. I have some questions regarding the classic 2 stage CMOS opamp (or for that matter any analog ckt):
When one starts a design from scratch, how does one determine the device sizes to start with? Hand calculations? I tried following the procedure in Allen & Holberg for a 2-stage CMOS opamp, but found that with the calculated device sizes simulation is no where near the calculated performance.
I know most of the times designers pick an older circuit and work on making modifications to it. But how does one approach if he has to start from scratch?
