mynick
Newbie level 1
can you connect atx/atx 12v output to 5v output of another atx supply or are there gnd problems?Unscrewing PCB off the case makes gnd float (floats anyway when you plug it in the 2 pin wall socket)
and possibly each will set its current to Vtotal/Load and regulate just it's own output voltage-i.e what kind of small signal transfer function you will get
