Qwerty112233
Member level 2
In physically designing a floorplan and doing place and route - how do you deal with 2 instances of the same module?
Case A : same instance stamped twice into the floorplan?
Case B: both flat as sea of gates in the floorplan (not hierarchically implemented and stamped)
Q. What happens if there's an eco fix found in rtl through verification.
in case of A : we only need to apply the eco fix to the instance - then do PNR once - its stamped twice automatically..
Q. In case B : do we need to apply the patch to both rtl instantiations separately and re-synthesize and do pnr on both separately?
Case A sounds like the better choice?
