Integer
Junior Member level 1
Hi all!
I have the 2 stroke motorcycle which have restriction on CDI which couldn't be removed. Problem is that CDI is also responsible for controlling the valve in the exhaust. And I've come up to the idea, to buy cheap DC CDI of some scooter or something like that and use that CDI for creating spark and leave original CDI to control the valve.
Thing what I don't know, is, should I put output for ignition coil from my original CDI to ground, and would this thing work, or it will be white smoke?
Thanks!
Thanks!
