julianodelan
Newbie
I'm currently designing a dual active bridge with TO 247-4 SiC MOSFETs, connected to a 2.5kV DC-link. I think that a PCB design for the power connections is not the best idea, also because i am not entirely sure if the distance between drain and source pins is enough for that voltage level. Even i was considering to remove the drain pin and just use the backside of the MOSFET. Should i consider mounting it with cooper bars? or from the thermal and the isolation perspective, a thicker PCB design should be enough?
Thanks in advance!
Thanks in advance!
