2.54mm socket housing not available?
cupoftea
Advanced Member level 6
I have an SMPS PFC controller which is on a daughter board which is mounted vertically to the main SMPS board. It needs to be easily disconnected/reconnected. I need to bring signals (sense and FET drive etc) on to the daughter board from the main board.
As such I will solder one of these 2row connectors to the daughter board….
MC34769:
https://uk.farnell.com/multicomp/mc34769/header-2-row-r-angle-10way/dp/1593451?ost=mc34769
The thing is, I cant find the socket housing which mates with this?...the bit that will be soldered on to the main board. I can only find this…
https://www.farnell.com/datasheets/3148611.pdf
..which has no solder pins….or this..
https://uk.farnell.com/fischer-elektronik/mk201-100z/header-socket-2-54mm-100way/dp/1322596
..which is too shallow.
Could you advise on a suitable housing, or suggest another way……(I am slightly against any solution which means having to buy an expensive crimp tool)
if you are trying to connectorise connections - such as shunt voltages, that are less than 100mV, take care to ensure some current flows thru the connector - i.e. at least 1mA - this will serve to stop the touching faces oxidising over time and essentially going open circuit for low voltages and very little thru current.
p.s. connectorising any important low volt signal should only be done if absolutely necessary because of the above - and the tendency of things to blow up if a current signal goes to zero - when in reality the current is very high.
where it has to happen - gold contacts on male & female and well crimped wires are preferred ...
