is there one component that itself can do the job ?
Best way is to use PLL Synthesizer to generate sine way in which you will have a lot of freedom like you can use micro-controller trigger to customize it according to your desire.
Then it is very easy you can generate sine wave using low pass filter at 1Ghz on your clock and you will get a perfect sine wave sync with your clock and will appear when clock is available.
is there a pll synthesizer or a certain logic system that can do the job ? just exploring other options.
