Ads 2009 on win 7 simulation problem
VIP_TEMAA
Member level 2
Member level 2
WARNING: Could not create the dataset
since no citi files could be found.
HOW TO SOLVE IT
Hello
I think you are using a calibrated port. This kind of port is used just with transmission line because it is calibrated by extending the line length and deembedding it at the end of the simulation.
In your case, you have to use an internal port. Momentum -> Port -> Property
I MAKE THESE
BUT I THINK SOME FILE MISSED
OK for the simulation. But did you try to change the kind of port you are using ?
The port is the arrow you put at the corner of your structure.
YES I TRY TO CHANG THE STRUCTURE
THE SAME PROBLEM
FOR CITIFILE
I DONT KNOW HOW TO SOLVE
THIS PROBLEM COMING
hi..
One reason could be if u dont have enough RAM it gives the same error.
Other reason may be port must be on Face not on the corner ..
yes, I think the problem is that you can't face on a inersection of two faces, you should only point to one face.
the laptop is new the ram 4gb
I MAKE MANY STRUCTURE WITHE MANY SIMULATION AS SAME PROBLE
OK CAN U GIVE ME SIMPLE STRUCTURE U SIMULATED AND TESTED ITS OK
I CAN TESTED IN MY LAPTOP TO SEE MAY BE SOTHING ERROR IM MY STEPS
THANKS
This not big project only small to test the program
ima biggneier in the program
first time i used
i will upload any project soon
thanks
I have encountered the same problem (no citifiles found) when the number of unknowns are high that ur CPU can't handle...
In order to check that change ur mesh size and see the number of unknowns....
Try changing ur port position also..
May u post the ads layout file.. so as to help u..
Thank u
the structura is small with parameter from 1 to 10 ghz
---------- Post added at 09:43 ---------- Previous post was at 08:40 ----------
MY FRIEN TRY TO INSTALL ADS2009 TO HIS DESKTOP WIN 7 64-BIT
SAME PROBLEM WITH CITIFILE COMING
ALSO HE INSTAL THE PROGRAM WIT WIN 7 32-BIT ITS WORKING WITH OUT PROBLEM
ITS MEAN THE SOFTWARE resistant WITH 6B-BIT
IF THERE SOFTWARE OR SOMTHING FIX THE PROBLE
THANKS
the problem not solved yet
i install win 7 pro 32bit also i install vista home primum 32
not working the simulation
No comments for RAM problems, my machine runs on Win 7 64 Bit, 8GB RAM, Core i5 2600
but I got the same error "...no citi files could be found"
Just untick "Edge mesh" in Mesh setup. It works perfectly.
Try this:
Start ADS2009
Run task manager (Ctrl+Alt+Del)
In processes tab, find "hpeesofemx.exe" and right click it, choose "Set Affinity"
Untick to reduce CPUs if you have multicore. Simulation should work perfectly with CPU 0 & CPU 1 selected. You can raise CPU number later to check if it still work.(My case works with 6 in 8 CPUs).
Good luck.
HI FOR ALL
THE ADS NOT WORKING ON WIN 7 64-BIT
MY SOLUTION WAS TO INSTALL WIN XP BY USING Oracle VM VirtualBox THEN YOU CAN WORK ON ADS ON WIN7
I TRY DIFFRENT SOLUTION THIS THE BEST
Try this:
Start ADS2009
Good luck.
Thank you very much.
It worked.
Try this:
Start ADS2009
Good luck.
i done this but it is showing the operation could not be completed.
Thank you very much,finally it working
