eanema
Member level 2
Hi All,
I'm trying to build a constant current boost converter to drive a chain of LEDs. I have picked an appropriate inductor, (over kill for the situation - 330 uH, 600 mA saturation current) I didn't realise that the output would be so dependent on the capacitance though. I hooked up the circuit as attached.
The LT1172 data sheet is here.
I choose the 68Ω resistor because I figured that the converter would do its best to set the output voltage to what ever it needs to be at to maintain the feed back voltage at 1.24v (see the block diagram in the data sheet) V=IR, 1.24v/20mA~=68 ohms. This seems to work, but is very dependent on the capacitor. I found that using an electrolytic 4.7uF cap rated at 60v worked best but the feed back voltage never reached 1.24v. The closest it got was ~1.1v and the worst (with other capacitors) was ~0.3v or 0v with no capacitor present. This means that I never reached the expected 18.2 mA, the closest I got was 16.2 mA.
Essentially, my question is this: how do I choose the correct capacitor.
Also, how important is the choice of diode? Could this be effecting my current problem?
