[SOLVED] Display Numbers on LCD Mikroc
tahir4awan
Full Member level 4
Full Member level 4
Germany
I am using MikroC compiler and PIC16F877. I have tried almost all C compilers but I found Mikroc to be the best compiler.
My question is it is very simple to display characters on LCD but I want to display numbers or integer to be displayed on LCD.
for example
int x;
x = 25
lcd_out(1,1,x);
note that this is not actual program it is just for example.
I tried this code:
void main() {
char txt[4];
int t;
t=255;
ByteToStr(t, txt);
LCD_Out(1,1,txt);
but the problem is that when value of t is bigger than 255 the no resets to 0.
I also tried long int t but nothing happened. and when I type long char txt[4] it is giving error.
try
WordToStr(t, txt);
IntToStr(t, txt); for bigger
Raj you really helped me thanks. Don't mind it if I ask you last two questions.
What is purpose of no in square brackets txt[4] what I learned in C it is an array. Why not it is simply char txt
second below is my program code and output is in image. Can you tell me why there are spaces in second row of LCD.
---------- Post added at 02:35 ---------- Previous post was at 02:34 ----------
void main() {
char txt[6];
int t;
t=255;
ByteToStr(t, txt);
delay_ms(500);
LCD_Out(1,1,txt);
t = 256;
wordToStr(t, txt);
delay_ms(500);
LCD_out(2,1,txt);
1. functions like IntToStr() and WordToStr() convert numbers into strings so to store that string, you need to declare a string first which, in C, is an array of characters.
2. These functions convert numbers into a string of fixed length and add spaces to the left if the number is small. you can get rid of those spaces using Ltrim()
try
Lcd_Out(2, 1, Ltrim(txt));
---------- Post added at 23:31 ---------- Previous post was at 23:28 ----------
if you have any confusions about the Library functions of mikroC, just double click the function name in the library manager. it will show you the detailed documentation of that function.
