Re: Sim300cz - at commands - gprs
Kandeepan
Junior Member level 1
Dear All, Could any one help me where did I go wrong in the following AT Command
AT
OK
AT+CREG?
+CREG: 0,1
OK
AT+CGATT=1
OK
AT+CGDCONT=1,"IP","paygwap"
OK
AT+CSTT="paygwap",Orange","multimedia"
ERROR
An early reply is very much appriciated.
Thanks and kind regards
Kande
Can u pls help me hw can i learn to write at command.....book?
AT Commands are product based..So it is always better to follow the concerned Product's Data Sheet- AT Commands
AT //ATTENTION COMMAND
ok
AT+CGREG? //NETWORK REGISTRATION STATUS
AT+CGREG=1
STETUS SHOULD BE 1,1
Parameter
<n> 0 disable network registration unsolicited result code
1 enable network registration unsolicited result code +CGREG:<stat>
2 enable network registration and location information unsolicited result code +CGREG: <stat>[,<lac>,<ci>]
<stat>
0 not registered, ME is not currently searching a new operator to register to
1 registered
AT+CGATT? //ATTACH/DETACH FROM GPRS SERVICE
AT+CGATT=1 //ATTACH GPRS SERVICES
<state> indicates the state of GPRS attachment
0 – detached
1 – attached
Other values are reserved and will result in an ERROR response to the execution command.
AT+CSTT="airtelgprs.com","","" //START TASK AND SET APN, USER NAME, PASSWORD
AT+CIICR //BRING UP WIRELESS CONNECTION WITH GPRS OR CSD
AT+CIFSR //GET LOCAL IP ADDRESS
AT+CIPSTART="TCP","74.125.79.83","80" //GMAIL SERVER IP ADDR AND PORT NO.
OK
CONNECT OK
AT+CIPSEND(ENTER)
>MESSAGE
CTRL z
SEND
OK
follow this, it worked for me doe simcom module
Hi Shivaram,Thanks for your response. Could you please let me know how to set up the "CIICR - PDP to Active" I have got the following when I do the AT Commands
AT+CIICR?
OK
AT+CIICR
ERROR
+PDP: DEACT
AT+CIICR=?
ERROR
Looking forward to hear from you soon.
Thanks
you have the pdf document of AT commands. I am unable to attach the file so sending you link
Hi Shivram, Thanks for the data sheet. I do not know where I'm going wrong mate.
T+CGDCONT=1,"IP","paygwap",
OK
AT+CGDCONT=?
+CGDCONT: (1-10),"IP",,,(0,1),(0,1)
OK
AT+CGDCONT?
+CGDCONT: 1,"IP","paygwap","",1,1
OK
AT+CGPADDR?
ERROR
AT+CGPADDR=?
+CGPADDR: (1)
OK
AT+CDNSCFG=?
OK
AT+CDNSCFG="158.043.192.001","158.043.128.001"
OK
AT+CDNSCFG?
PrimaryDns:158.43.192.1
SecondaryDns:158.43.128.1
OK
AT+CSTT=?
+CSTT: "APN","USER","PWD"
OK
AT+CSTT="paygwap","Orange","multimedia"
ERROR
AT+CSTT?
+CSTT: "paygwap","Orange","multimedia"
OK
AT+CIICR
ERROR
AT+CIICR?
OK
AT+CIICR=?
ERROR
ERROR
AT+CIPSTATUS
OK
STATE: PDP DEACT
AT+IPSTATUS
ERROR
AT+CIPSTATUS=?
OK
AT+CIPSTATUS?
ERROR
Please have look if time permits you. Thanks . Kandeepan
Can you check AT+CSQ=?
at+csq?
i there signal near you place when you use modem . if you get 99,99 then there is some problem
Hi Shivaram, Thanks for your response. I have tried the ""AT+CSQ" and got the following
AT+CSQ=?
+CSQ: (0-31,99),(0-7,99)
OK
AT+CSQ?
ERROR
AT+CSQ
+CSQ: 5,0
OK
I do not know where I'm going wrong mate..
Appriciated your time and concerns.
Thanks. Kandeepan
This above post works for me.. and whatever you tries is same as i did.
I doubt the module, as now-a-days there are lot of complaints about SIMCOM GPRS functionality.
Can you get any information from the vendor.
Meanwhile i will test it with another 5 or 6 modules and update you by this weekend
Hi Shivaram, I have sorted out the following
AT+CIICR
AT+CIFSR
AT+CIPSTATUS
AT+CIPHEAD
AT+CDNSORIP
Now, I have struck at "AT+CIPSTART".
I'm trying to connect to an FTP sever ftp://212.157.119.102
Orange Mobile Port no is 8080. I'm I correct ? If not,Which port no I should put in?
AT+CIPSTART="TCP","212.157.119.102","8080"
OK
STATE: TCP CONNECTING
CONNECT FAIL
If time permits u please have a look mate. Thanks .
Kandeepan
port no is got from the gprs setting of particular service provider.
My suggestion is first try with indian service provider like airtel , or vodafone if possible.
for orange alternate port numbers are 9201
Reactions: ramina
    ramina
Hi Shivaram, I have gone upto
AT
OK
AT+CGDCONT=1,"IP","orangeinternet","192.168.71.35",1,1
OK
OK
AT+CSTT="orangeinternet","",""
OK
AT+CIICR
OK
AT+CIFSR
10.52.83.134
AT+CIPSTATUS
OK
STATE: IP STATUS
AT+CIPHEAD=1
OK
AT+CDNSORIP=1
OK
AT+CIPSTART="TCP","www.google.com","80"
OK
CONNECT OK
Now, I need to connect to my ftp server.
Update u soon.
Regards
Kandeepan
---------- Post added at 16:49 ---------- Previous post was at 16:43 ----------
Further to my note.. Could u please let me know which port no I should use it for this command "AT+CIPSTART"? The ornage one or the FTP server one? I'm confused
Are you seeing output in hyperterminal, then hyperterminal cannot display webpage. it will take some time to get response from site after connection maybe 2 or 3 min. then it starts printing some characters and text on terminal. copy that and save it as ".htm" and open in explorer you can see what was the real response from the server.....
Hi Shivaram, I was able to go up to ftp connection.
AT+CIPSTART="TCP","212.157.119.102","21"
OK
CONNECT OK
+IPD65:220-***********************************************************
+IPD38:220- PLASTIC OMNIUM SYSTEMES URBAINS
+IPD6:220-
+IPD65:220 ***********************************************************
+IPD54:421 Login time exceeded. Closing control connection.
How can I login to my FTP server? Which AT Commands I should use?
Any Idea?
Thanks.
Kandeepan
At my office. i am unable to recollect. check if thre is any command like AT+WIPCREATE=4,1,"FTP server",21,"username","passwd"
Once you get things going.. please post the complete procedure with explanation so that it is helpful for everybody
HELLO this attachment will help you more . read it
if any one have the doubt ask here back
  • quick start of GSM communication.rar
can you tell what this document contains in specific................
Nothing for a newbeee at least.
it taken from the specification and pasted and txt file if i am mot wrong.
better post the pdf from companies which have correct information rather than redoing and copying the same information as many things many be misinterpreted.
Reactions: MRAMA
    MRAMA
Hi Shivaram,
I tried the command and got the following response
AT+WIPCREATE=4,1,"212.157.119.102",21,"Username","Password"
ERROR
AT+WIPCREATE?
ERROR
AT+WIPCREATE=?
ERROR
All I want how to Login to and FTP server using AT Commands. I tried AT+CIPSEND and did not work out.
can you refer this link and let me know
https://www.embeddedarm.com/documen...eloperguide-gsm-gprs-ip-commands-s000333b.pdf
page no 25
---------- Post added at 01:56 ---------- Previous post was at 01:55 ----------
sorry that command is for wavecom modem
---------- Post added at 01:56 ---------- Previous post was at 01:56 ----------
earlier post was for wavecom. now you refer the link please
