The simplest circuit that can do this conversion would be the basic transistor inverter supplied from 12V power source ..
See atteched picture (or google for transistor inverter) ..
This won`t work because you`ll lose the square pulse unless you have it regulated. Use an opamp circuit.. that will do it. You are misleading the house and it is against the standing orders of this forum.
