need to fix hold violation
chanducs24
Member level 2
Member level 2
hi
i had a one hold violation for one path, slack is -0.0027 after routing..can anyone guide me how to fix this and without any geometry violations after routing has been done?
Thanks,
chandra.
How much more metal do you need to delay the signal enough to get rid of the violation?
Could you reroute the signal so that is travels a longer path?
Hi Chandra,
There may be different approaches to fix it;
1 - If you don't want to modify any routing:
- a. Replace any of the cells on the timing path with their slower "pin compatible" versions. In your case the hold violation is very small, and I guess changing 1 cell should be sufficient.
- b. Replace the flop with a different hold time requirement. However this may be a little risky as it may also affect clock tree.
2 - If you are allowed to do ECO routing then add a buffer/delay cell to the violating pin. Then do ECO routing.
3 - You can also play with the routing to increase delay added by the routing itself. e.g. increasing the net length will increase the delay.
I hope it helps,
BR,
Gokhan
Thanks Gokhan..
ur information is helpful..
chandra.
What is the setup margin available for the hold violating path?
If the setup margin is greater than +5 ps, then I would replace the driver cell of the D-Pin with "HVT" cell.
If the setup margin is just met, then I would choose any of the methods mentioned by Gokhan.
Hope this helps!.
When I see a violation of 2.7ps, my first questions are :
1- clock and data deraiting?
2- hold time margin?
3- SI mode active?
If you have the SI mode enable, a marge around 100ps, and a debare of 5%, for me the design is "clean".
