dariush_abbasi
Member level 3
Would you please tell me among the 8051s and AVRs and PICs and ARMs and dsPIC30Fs and dsPIC33Fs which one is faster?
I need a comparison between the common devices,for instance,between dsPIC30F4013(MAX 120MHz) and AT91SAM7S64(MAX 55MHz) not very expensive ones.
As far as i know most PICs,for example,need 4 cycles per instruction,so is it fair to say that PIC18F4550,for example,with the maximum frequency of 48Mhz is same as a 32-bit Cortex™-M3 ARM with 12Mhz?
Does AT91SAM7S64 need 1 cycle per instruction?
Which one is more important for faster execution of instructions?
1-MIPS/MHz
or
2-Frequency itself?
for example as you know:
PIC32MX5XX/6XX/7XX has 80 MHz maximum frequency with 1.56 DMIPS/MHz (Dhrystone 2.1) performance(if you calculate the MIPS would be 124MIPS),
but dsPIC30Fs' MAX Frequency is about 120MHz with Up to 30 MIPS operation.
Which one is faster?
Instructions per second - Wikipedia, the free encyclopedia
Any suggestion highly appreciated.
1-MIPS/MHz
or
2-Frequency itself?
