[SOLVED] LCD display chararcter in reverse direction
bskumar7080
Member level 2
Member level 2
India
Hi all,
I interfaced 20 x 4 lCD with pic18f452. i am getting diaplay in reverse direction, wht is wrong in this code
#include <p18f452.h>
#include <xlcd.h>
#include <delays.h>
#pragma config OSC  = HS
     #pragma config PWRT = ON
     #pragma config WDT  = OFF, WDTPS = 1
     #pragma config LVP  = OFF
     #pragma config DEBUG = OFF
     #pragma config CP0  = OFF,CP1 = OFF,CP2 = OFF,CP3 = OFF,CPB = OFF,CPD = OFF
     #pragma config WRT0 = OFF,WRT1 = OFF,WRT2 = OFF,WRT3 = OFF,WRTB = OFF,WRTC = OFF,WRTD = OFF
     #pragma config EBTR0 = OFF,EBTR1 = OFF,EBTR2 = OFF,EBTR3 = OFF,EBTRB = OFF
void DelayFor18TCY( void )
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
Nop();
void DelayPORXLCD (void)
Delay1KTCYx(75); // Delay of 15ms
// Cycles = (TimeDelay * Fosc) / 4
// Cycles = (15ms * 16MHz) / 4
// Cycles = 60,000
return;
void DelayXLCD (void)
Delay1KTCYx(25); // Delay of 5ms
// Cycles = (5ms * 16MHz) / 4
// Cycles = 20,000
return;
char XLCD_Disp1[] = "MICROCHIP  ";
void main( void )
// configure external LCD
OpenXLCD( FOUR_BIT & LINE_5X10);
BusyXLCD();
SetDDRamAddr(0x09);
BusyXLCD();
putsXLCD(XLCD_Disp1);
BusyXLCD();
while(1);
what is wrong in this code
I am using C18 compiler..
How to write command to shift Display Left, Cursor On, Cursor off.
I am getting correct output when i pass characters individually, when i pass string i am getting reverse
what is the problem,
I am able to Off cursor, but shift_left cursor, commands (WriteCmdXLCD(SHIFT_CUR_RIGHT)) are not working
include <p18f452.h>
 #include <xlcd.h>
 #include <delays.h>
 Nop();
 Nop();
 Nop();
 Nop();
 Nop();
 Nop();
 Nop();
 Nop();
 Nop();
 Nop();
 Nop();
 Nop();
 Nop();
 Nop();
 Nop();
 Nop();
 Nop();
 Nop();
 Nop();
 // Cycles = 60,000
 return;
 // Cycles = 20,000
 return;
 char XLCD_Disp1[] = "M";
 char XLCD_Disp2[] = "I";
 char XLCD_Disp3[] = "C";
 char XLCD_Disp4[] = "R";
 char XLCD_Disp5[] = "O";
 char XLCD_Disp6[] = "C";
 char XLCD_Disp7[] = "H";
 char XLCD_Disp8[] = "I";
 char XLCD_Disp9[] = "P";
 void main( void )
 OpenXLCD( FOUR_BIT & LINES_5X7);
 Delay10KTCYx(20);
  WriteCmdXLCD(DON&CURSOR_OFF&BLINK_OFF);
  while(BusyXLCD());
  Delay10KTCYx(20);
 BusyXLCD();
 SetDDRamAddr(0x01);
 BusyXLCD();
 SetDDRamAddr(0x02);
 putsXLCD(XLCD_Disp2);
 BusyXLCD();
 SetDDRamAddr(0x03);
 putsXLCD(XLCD_Disp3);
 BusyXLCD();
 SetDDRamAddr(0x04);
 putsXLCD(XLCD_Disp4);
 BusyXLCD();
 SetDDRamAddr(0x05);
 putsXLCD(XLCD_Disp5);
 BusyXLCD();
 SetDDRamAddr(0x06);
 putsXLCD(XLCD_Disp6);
 BusyXLCD();
 SetDDRamAddr(0x07);
 putsXLCD(XLCD_Disp7);
 BusyXLCD();
 SetDDRamAddr(0x08);
 putsXLCD(XLCD_Disp8);
 BusyXLCD();
 SetDDRamAddr(0x09);
 putsXLCD(XLCD_Disp9);
 BusyXLCD();
 SetDDRamAddr(0x40);
 BusyXLCD();
 while(1);
It works !!!!!!!!!
I set the cursor to Return home and shifted display right
