18F97J60+Ethernet+USB+RS232
lanndegeth
Newbie level 5
Newbie level 5
Hi all, i'm working on a project that consist of ethernet, usb, rs232, lcd and keypad. Because of that reason I decided to use PIC18f97j60 microcontroller. I assigned TX1-RX1 for rs232, and TX2-RX2 via FDTI chip for USB. Is it possible to use all that devices at the same time?
I have started to project two weeks ago, and wrote keypad, lcd and rs232 drivers. I found TCP Stack for ethernet work. It is time to work on USB. But that question confused me a lot. Could you help me? Thank you.
It looks like EUSART1 and EUSART2 are independent so you can use them both at the same time.
Interesting project BTW :)
hi lanndegeth, could you share the library of the PIC18F97J60 Proteus, I see that your image is that pic proteus, or where there is this version of proteus pic
Please share the PIC18f97j60 proteus model with us. Thanks
---------- Post added at 14:31 ---------- Previous post was at 14:29 ----------
I need, too!
