18f4550 turn on turn off pins
ggmssr
Member level 2
Member level 2
Hello
i need help
I use 18f4550 pic and need to switch on and off some pic output pins, to turn some led or relay on or off.
I use mikroc. how this can be done?
Second qustion can this output be as toggle switch?
Toggle code. switch is connected to RB0 such that if switch is pressed RB0 is 1. This toggles RA0
void main() {
      if(PORTB.F0 == 1) {
           Delay_ms(30);
           if(PORTB.F0 == 1) {
                     PORTA.F0 = ~PORTA.F0 //toggles RA0 pin
Reactions: ggmssr
    ggmssr
Big thanks,
Can I use port C and how will go for other pins.
Like this?
PORTC.F0 = ~PORTC.F0 //toggles RC0 pin
PORTC.F1 = ~PORTC.F1 //toggles RC1 pin
Do i need some pins initialisaation?
Where is RC3 pin on 18f4550?
Yes you can do like that. You can also refer to it like this:
RC0_bit = ~ RC0_bit;
RC0_bit is the same thing as PORTC.F0.
You need to make the pins output.
To write to RC0, RC0 must be declared as output. This is done by clearing the corresponding TRIS bit:
TRISC0_bit = 0;
By clearing the entire TRISC, you make all PORTC pins output:
TRISC = 0;
Go through the datasheet:
ww1.microchip.com/downloads/en/devicedoc/39632c.pdf
You can find the pinout in the datasheet. Here it is:
Hope this helps.
Tahmid.
Reactions: ggmssr
    ggmssr
Thanks Tahmid you are helpful,
Can I ask I dont see RC3 in 18f4550 pinout scheme? Is that mean that I cant use bit 2 on port C?
Looks like PIC 18F4550 doesn't have RC3.
It has RC0, RC1, RC2, RC4, RC5, RC6 and RC7.
Of course you can. PIC 18F4550 has bit 2 on PORTC - RC2. It doesn't have bit 3 on PORTC - RC3.
Hope this helps.
Tahmid.
Reactions: ggmssr
    ggmssr
Ok, big thanks.
Ca I ask one more thing, I'm total beginner?
What is purpose of LAT and TRIS ?
LATB2_bit
TRISB2_bit
Just for clarification:
I found this on page 119 of the datasheet:
The last sentence clearly tells of the absence of RC3.
Hope this helps.
Tahmid.
Reactions: ggmssr
    ggmssr
LATB2_bit
TRISB2_bit
Sorry for this basic questions. :-(
TRIS sets whether the pin should be output or input. If TRISB2_bit is set to 1, PORTB2 is set as input. If TRISB2_bit is set to 0, PORTB2 is set as output.
In PIC18 when writing to the ports, you should write to LAT. If you want PORTB2 to output 1, write
LATB2_bit = 1;
If you want PORTB2 to output 0, write
LATB2_bit = 0;
Hope this helps.
Tahmid.
Reactions: ggmssr
    ggmssr
Mr. Tahmid you are great teacher and you are very helpfull.
Thanks.
