s there microphones component in Proteus
Rooney_04
Member level 2
Member level 2
Is there microphones component in Proteus ..because i couldnt find it......if there is no microphone....is there such way that got other component can replace microphone function in the Proteus
how i could signal generator ? Could be more specific explanation?
Just use the signal generator to produce some signal to go into your circuit. But, it wont be as good as having a microphone there :)
if signal generator was used....will it effect the when i convert it ares for pcb layout
Signal generator will not be converted to PCB layout :) If you need the layout, then replace it with something similar like capacitors for the layout purposes :)
