VHDL UART code written by Bert Cuzea of alse-fr.com
varunmalhotra
Newbie level 5
Newbie level 5
Hi Guys,
I am sending data via a serial cable to the Altera DE2 FPGA. but i am not getting the correct values. I think there might be a problem with the baud generator. Can some one help me with the baud gen. I have a 50 Mhz systme clock. I am trying to get the 115200 baud rate. Even a small template will do. Also
how to get to the actual statistics for the baud generator. (how the clk should be divided etc.) Apart from the this Rx code and a baud genrator. do i need any other module as well.
Thanks
This is my Rx code.
LIBRARY ieee;
USE ieee.Std_logic_1164.ALL;
USE ieee.Std_logic_unsigned.ALL;
ENTITY serial_comm IS
PORT(
clk : IN std_logic;
rst : IN std_logic;
rx : IN std_logic;
count : out std_logic_vector(3 downto 0); -- used for debugging
dout : OUT std_logic_vector (7 downto 0)
END serial_comm;
ARCHITECTURE simple OF serial_comm IS
type state is (idle, s0, s1, s2, s3, s4, s5, s6, s7,stop);
signal current_state, next_state : state;
signal databuffer : std_logic_vector(7 downto 0);
BEGIN
seq : process(rst,clk,rx)
begin
if rst = '0' then
dout <= "00000000";
databuffer <= "00000000";
current_state <= idle;
else
if rising_edge(clk) then
current_state <= next_state;
case current_state is
when idle =>
when s0 =>
databuffer(0) <= rx;
when s1 =>
databuffer(1) <= rx;
when s2 =>
databuffer(2) <= rx;
when s3 =>
databuffer(3) <= rx;
when s4 =>
databuffer(4) <= rx;
when s5 =>
databuffer(5) <= rx;
when s6 =>
databuffer(6) <= rx;
when s7 =>
databuffer(7) <= rx;
when stop =>
dout <= databuffer;
when others =>
dout <= "00000000";
end case;
end if;
end if;
end process;
receive: process (rst,current_state,clk,rx)
begin
when idle =>
if rx = '0' then
next_state <= s0;
else
next_state <= idle;
end if;
when s0 =>
next_state <= s1;
when s1 =>
next_state <= s2;
when s2 =>
next_state <= s3;
when s3 =>
next_state <= s4;
when s4 =>
next_state <= s5;
when s5 =>
next_state <= s6;
when s6 =>
next_state <= s7;
when s7 =>
next_state <= stop;
when stop =>
if rx = '0' then
next_state <= s0;
else
next_state <= idle;
end if;
when others =>
null;
end case;
end process;
-----------debug-------------------------------------------
process(rst,clk,current_state)
begin
if rst = '0' then
count <= "0000";
else
when idle =>
count <= "1001";
when s0 =>
count <= "0000";
when s1 =>
count <= "0001";
when s2 =>
count <= "0010";
when s3 =>
count <= "0011";
when s4 =>
count <= "0100";
when s5 =>
count <= "0101";
when s6 =>
count <= "0110";
when s7 =>
count <= "0111";
when stop =>
count <="1000";
when others =>
count <= "1111";
end case;
end if;
end if;
end process;
---------------------------------delete after wards-----------------------
END;
Rs- 232 problem
Hi varunmalhotra,
I have excellent VHDL UART code written by Bert Cuzea of alse-fr.com. Nice simple code and I have been using 115200 baud to send data from FPGA to PC. No problems works great. Let me know and I will post UART code here.
Cheers,
Scanman
Re: Rs- 232 problem
Thanks Scanman
that would be great..please post the code.
thanks alot for the prompt reply
Re: Rs- 232 problem
Varunmalhotra,
Here is the code. Thanks to Bert Cuzea of alse-fr.com for sharing his awesome UART with us.
Cheers,
Scanman
Rs- 232 problem
Hey scanman,
i dont see the code. may be it dodnt attach with the post.
Please have a look
Thanks
Added after 2 minutes:
Sorry about that, i see it now.
Thanks
master i have open the file, and open it using Xilinx ISE 8.2i after that ,when trying to assign package pin i am blank to what should be filled here(the picture i insert)
Here is a state machine for transmitting bytes from FPGA to PC via RS-232.
  • uart_transmit.7z
Re: Rs- 232 problem
Hey scanman,
Please have a look
Thanks
Thanks
@ varun, @scanman
please tell me how did you get the zip file . i am not able to see it
oh i see it now :p
for others who might have the same problem
u must be logged in to see the .zip files
Re: Rs- 232 problem
@scanman
Hi can you send me the detailed documentation of the uart ip
@varun
did you verified it with a board . share you experience
i am trying to interface the uart ip with my vhdl module so that it can communicate with my spartan 6 fpga board.
seniors pour in some thoughts
Re: Rs- 232 problem
@scanman
can you share the other modules like applic.vhd and uarts.vhd
I found excellent VHDL UART code written by Bert Cuzea of alse-fr.com.
full version:
direct links on french sites:
:roll:
  • ALSE_Uart_simple.rar
