16f877a programming using mplab ide
angelocasuga
philippines
are there any kind-hearted people who could help by providing a simple source code on using mplab ide?
i'm a beginner in using this application and kinda confused using it.
and can somebody help me by explaining each command line?
thanks..
much love.
The attachment may help you.
V.Durgai dass
thank you mr for the user manual..
uhm?
can you do me a favor sir?
can you provide me a sample source code of mplab for a 16f877a using assembler; which every command line indicated its function?
this would be a great help for me being a starter in this field.
thank you so much for you and every one who could help me though.
God bless us.
Attached is a complete MPlab project with a working example .asm file that contains some guide notes.
Unpack the rar file and copy the entire folder into the folder C\.. Microchip\
Then start Mplab and Project, Open, angel877.
That should open with the .asm file on the screen, if not simply Open File
You can then Project - Build All and it will produce the .hex file to program into your chip.
