How do i make a 200W modified sine wave ups?
trivikram2k10
Newbie level 1
Newbie level 1
India
I am a student in India and i wanted to make a modified sine wave UPS (12v DC to 220V AC), The wattage need not be very high (even 100-150W is okay). Also, it would help if it could use relays or transistors to switch to back up quickly in case of a power failure. A few seconds delay is also acceptable. Can someone help????
Hi, this can be a problem, if you look into the forum i post some inverters circute diagram using sg3524 pwm ic it work fine with modified sine output,and to control the inverter on when ever their is power supply failure normaly the shut down pin is used for the control.
Good Morning.
Escuse my English, I speak Spanish.
I have the response time circuit. I like interchange whit the pwm regulation circuit.
Mi Email - alhida55@hotmail.com
Here attached simple circuit for 250w semi sinusoidal inverter
  • 250w semiSine.pdf
HI
Also Attached POLISH version attachment........ Enjoy:lol:
  • Przetwornica na SG3524.pdf
