milvapp
Member level 5
- Joined
- Apr 17, 2010
- Messages
- 88
- Helped
- 3
- Reputation
- 6
- Reaction score
- 2
- Trophy points
- 1,288
- Location
- chania greece
- Activity points
- 1,882
Connect a unit current source (analogLib/idc or analogLib/isin) with AC magnitude=1 and any Frequency between Vout1 and gnd. Then run an ac analysis, sweeping the frequency between your points of interest. The voltage at Vout1 (i.e. over the isin source) is your frequency-dependent impedance: z = v/i . With i=1 , e.g. kVolts ≙ kOhms. From the low frequency part of the magnitude curve you can deduct the resistive part of the impedance, from the high frequency part you can get the reactive, i.e. the capacitive part.milvapp said:i want to find-calculate the total load capacitance at the output node (Vout1 as shown in the image).
