auroral
Newbie level 6
I'm pretty sure I'm going wrong on setting up the milkyway library for running ICC. Help me fix it!
I create a milkyway lib using create_mw_lib -technology <filename> <libname>
and then open_mw_lib <libname>
and then go on to import my verilog design files. The designs run clean on DC, but fail to even import on ICC. I've tried using different .tf and .plib files for setting up the milkyway library with the same outcome. I've also set the link library and target lib to be the same. What am I missing and/or where am I going wrong? Thanks for your time!
