converting vcd to saif
Mamdouh
Member level 1
Member level 1
Egypt
how can i convert a vcd file to a saif file or a toggle file ?
ljxpjpjljx said:
saif file? which format?
.saif format i used vcd2saif command but "You need to provide an RTL forward SAIF file" i dont know what is that file and how to generate it ??
you can use lib2saif or rtl2saif to generate the forward saif, but what i do not understand is when you use vcd2saif, i thind the file you need is vcd file, why forwrd saif file ?
FYI: vcd2saif -i vcd_file -o bsaif
attached the turbo_encoder.vcd , out.saif (forward saif file generated by rtl2saif) i used these files to generate saif file , the generated saif file is attached but it has no information i dont know whats wrong i used the command
vcd2saif -i turbo_encoder.vcd -o turbo_encoder.saif -rtl out.saif -format vhdl
yes my vcd2saif needs rtl forward saif file i dont know why if you have a vcd2saif tool that doesnt need rtl forward saif plz share
thx
thx
sorry to my misunderstand, you are right vcd2saif needs forward saif.
It seems that you had resolved your problem.
yes i resolved my proplem but i didnt use vcd2saif i natively created saif file from MODELSIM simulator
Hello I've the same problem. I want to generate a saif file from MODELSIM, which kind of MODELSIM are using? Can you suggest me how to create a saif file from MODELSIM? I'm trying to do it for about one week and I haven't solved my problem.
Please, help me
thx
Please, help me
thx
before starting the simulation and after loading the file write this line in the command line
power add /* this will report power for all nets in the design
or you can use
pwer add /top/* this will report power for all nets in the top file ( assuming that the top file is named top )
then do your simulations and write this line after finishing simulations
power report -all -bsaif file_name.saif
then exit the model sim and you will find the saif file created in the working directory
hope this helps
