verilog-A model for binary-to-thermometer decoder
sharkies
Member level 5
Member level 5
I am writing a verilog-A model for binary-to-thermometer decoder. NOT verilog!
For a beginner like me, this is quite tough...
I think I keep getting confused with all the verilog, verilog-ams, verilog-A syntax :cry:
compile errors everywhere,,
Really frustrating
I take a 3bit input, and need to output a 8bit...
I wrote a code that counts the total number of thermometer output signal that needs to be high
can somebody help me out ugh..
You can easily do it the generate construct, in the analog block. You first need to convert your binary input (say in[2:0]) into an integer (say sum) and then use a for loop as in the snippet below.
analog begin
	sum = 0;
	generate i (0,2)
		sum=sum+((V(in[i])>VT)?1:0)*pow(2,i);
	for (i=0; i<=7; i=i+1)
		if(i<sum)
			out_v[i]=1;
		else
			out_v[i]=0;
	generate i (7,0)
		V(out[i])<+transition(out_v[i],TD,TR,TF);
end
I guess you can put together the module...
Thank a bunch, problem solved :)
