ADS 2009 in Debian - start up
Vigort
Member level 4
Member level 4
Minsk
Hi!
Who can faced installation ADS in Debian? Itself ADS it was installed without problems. But when you run ads produces an error
~/Program Files/ADS2009U1/bin $./ads
Agilent Technologies
Advanced Design System
./ads [8]:.: eesofboot.sh: cannot open [There is no such file or the directory]
The file eesofboot.sh bin is present at a directory. In what there can be a problem?
Help me, please.
Hello Vigort,
I also just now decided to give ADS2009 a try, which is why I did a search on here about it. It also happens to be on debian. For it to start I needed to do 2 things. First make sure the HPEESOF_DIR environment variable is set to the install dir of ads2009. And 2nd add it's bin directory to your path.
So in your case something like:
~ $ cd  "~/Program Files/ADS2009U1"
~/Program Files/ADS2009U1 $ export HPEESOF_DIR=$(pwd)
~/Program Files/ADS2009U1 $ export PATH=${HPEESOF_DIR}/bin:${PATH}
I also noted that you have spaces in your directory name. Please be aware that on *nix that sometimes gives problems with programs and especially shell scripts. And I see ads itself is a korn shell script, so just beware.
Alright, now all I need is that trial license.
Anyway, hope this helps you.
mrflibble said:
Hello Vigort,
Hello, mrflibble!
Thanks for the information, but for me are a question:
Where to me to look this variable HPEESOF_DIR: in install or in the installed directory?
Thanks, I will consider on the future.
If it is really necessary to you, that I think that this question can be solved ;-)
P.S. You install "Complete" or "Custom" (with FlexNET files) versions ADS?
I used the installer to install in this directory: /opt/ads2009u1
Then I just did the following:
export HPEESOF_DIR=/opt/ads2009u1
export PATH=/opt/ads2009u1/bin:$PATH
ads
I'm always interested to hear about potential solutions. Especially when this potential solution works in linux. ;)
To answer your question, I did a custom install, complete with the flexnet files.
Added after 8 minutes:
To be more precise, I put it in a shell script called ads2009.sh like this:
#!/bin/sh
# Agilent ADS 2009 Update 1
ads $@
Then I can just call ads2009.sh from commandline, and it will even pass any needed argument.
hope that helps!
I use longer script:
1. I extend in.bashrc:
HPEESOF_DIR=/home/Programs/ADS2009U1
PATH=.:$HPEESOF_DIR/bin/linux_x86_64:$HPEESOF_DIR/bin:$PATH
LD_LIBRARY_PATH=$HPEESOF_DIR/adsptolemy/lib.linux_x86:$LD_LIBRARY_PATH
LD_LIBRARY_PATH=$HPEESOF_DIR/lib/linux_x86:$LD_LIBRARY_PATH
LD_LIBRARY_PATH=$HPEESOF_DIR/adsptolemy/lib.linux_x86_64:$LD_LIBRARY_PATH
LD_LIBRARY_PATH=$HPEESOF_DIR/lib/linux_x86_64:$LD_LIBRARY_PATH
SIMARCH=linux_x86_64
export HPEESOF_DIR
(It is recommended Agilent for 64 bit Linux, but thus loadtime slightly increases)
2. And a simple script for start ADS:
#!/bin/sh
#Startup script for ADS2006A
cd /home/igor/Programs/ADS2009U1/bin
ads
And that laziness each time to come into house directory ADS.
I will try your variant, can start will faster.
export HPEESOF_DIR
Yeah, you can do that too. Personally I prefer to put that sort of thing in a shell script. If only because quite often I have more than one version of a piece of software on my machine. If you put all the env vars in your .bashrc then that typically is for 1 specific install. And regarding the LD_LIBRARY_PATH, I noticed eesofboot.sh etc already takes care of that based on the HPEESOF_DIR variable.
But either way, I suppose it mostly comes down to personal preference. :)
Well it is the first my experience of installation ADS on linux. LD_LIBRARY_PATH I have registered, as for me produced an error libXm.so.3 (demanded 32 bit).
libXm.so.3 is provided by the libmotif3 debian package...
I know. Therefore also it was necessary to register LD since libmotif3 for me for 64, and he demanded 32 bats. At first I tried to solve by means of the character link in the directory/usr/lib32 but when has looked library that have seen: ELF 64-bit LSB shared object, has understood that such course will not help
I have installed ADS 2011.01 linux on Fedora in /usr/local/ADS2011_01
I start the lmgrd like this
Then i get this
My .bashrc looks like this
I get the error msg
Please help me out with the configuration in bashrc
Similar that at you doesn't find a file (symlink) libz.so.1. Try to install a packet zlib1-1.2.3-*.rpm
I have installed that now stuck with libXm.so.3
Unable to debug this!!
What is the package name for fedorax86_64??
First i did this
$yum whatprovides "*libXm.so.*"
and installed all the packages using yum
openmotif-2.3.3-1.fc14.i686
& lesstif-0.95.2-2.fc15.i686
then ran ads to which i got the same error
hpeesofde: error while loading shared libraries: libXm.so.3: cannot open shared object file: No such file or directory
Using Fedora 16 x86_64
To you it is necessary lib for x86x64: openmotif-2.3.3-*.rpm
In Debian I did so: Install libmotif3 (64bit packet libXm.so.3), than download libmotif3 for i686 unpackked from libmotif3 in a folder /usr/lib32 libXm.so.3 and libXm.so.3.0.*
I have installed both i686 and x86_64 versions
when is query for the packages its shows the packages!!
when i run ads
i also get this error /usr/local/ADS**/bin/ads[8]:.[13]:.[70]:.[7]:.[28]: lsb_release: not found [no such file or directory]
& /usr/local/ADS**/bin/ads[8]:.[13]:.[70]:.[7]:.line 29: lsb_release: not found
Using 64bit data display and simulation settings
Then libXm.so.3 error
