Master MCU (8051) and Slave MCU (8051) sample program
macer_0001
Member level 1
Member level 1
Manila
Is anyone here could help me. I am using 8051 microcontrollers. I read a Mode 3 communication for multicontrollers. But I dont see an example code. Could you give some simple code (assembly language) for master and for slave?
Your support is very much appreciated.
Thank you
Refer the page no 17 of this application note for assembly language program of Mode 3 (9 bit) Multiprocessor Communications (Master and Slave).
hope this help
regards
bassa
bassa, That information helps me a lot. Thank you for your support.
To macer_0001: Thanks for posting the quetion!!!
To Bassa: Thanks for the info! It helped me a lot!
wat application ...? i dont find any application here.....
---------- Post added at 22:28 ---------- Previous post was at 22:25 ----------
it would be helpful if get any circuit for this...........
any application that required master - slave serial communication
There are no specific circuit as such, normally master - slave connection between each master and slave devicess
Refer this lecture notes
