Pic ADC - Negative voltages.
mbprado
Newbie level 3
Newbie level 3
Hi everyone.
I have seen in another topic, an exemple in mikrobasic, of a 0v > +5v voltimeter .
Thamid's exemple bellow, works fine for me, but now, I need to work at -5v to +5v and I dont know how to do this.
Any Idea?
Tks for your help.
program softwarefor887Voltmeter
dim LCD_RS as sbit at RB4_bit
    LCD_EN as sbit at RB5_bit
    LCD_D4 as sbit at RB0_bit
    LCD_D5 as sbit at RB1_bit
    LCD_D6 as sbit at RB2_bit
    LCD_D7 as sbit at RB3_bit
    LCD_RS_Direction as sbit at TRISB4_bit
    LCD_EN_Direction as sbit at TRISB5_bit
    LCD_D4_Direction as sbit at TRISB0_bit
    LCD_D5_Direction as sbit at TRISB1_bit
    LCD_D6_Direction as sbit at TRISB2_bit
    LCD_D7_Direction as sbit at TRISB3_bit
dim ADCResult as longword
dim voltage as word[5]
dim display as string[5]
sub procedure GlobInit
    ANSEL = 1
    ANSELH = 0
    TRISA = 1
    TRISB = 0
    PORTB = 0
    LCD_Init()
    LCD_Cmd(_LCD_CLEAR)
    LCD_Cmd(_LCD_CURSOR_OFF)
    LCD_Out(1, 1, "Voltage:")
    LCD_Chr(1, 16, "V")
    display[1] = "."
end sub
main:
     GlobInit
     while true
           ADCResult = (ADC_Read(0) * 500) >> 10
           voltage[0] = ADCResult div 100
           voltage[1] = (ADCResult div 10) mod 10
           voltage[2] = ADCResult mod 10
           display[0] = voltage[0] + 48
           display[2] = voltage[1] + 48
           display[3] = voltage[2] + 48
     vout:
           LCD_Out(1, 10, display)
           delay_ms(50)
     wend
end.
You can try this method:
1. Feed the input voltage to two op-amp circuits: a non-inverting amp and an inverting amp with gain as required.
2. Feed these two op-amp outputs to two PIC input pins.
3. Connect two schottky diodes at the PIC inputs to prevent them going less than 0.3v.
4. Check both the input pins to see which one is greater than 0.3v.
5. Read the positive one, and determine whether it is the positive or negative voltage you are reading.
Hope this helps.
Tahmid.
Hope this helps.
Tahmid.
Tks for ur reply!
Its a good idea. In this case, I will have two distinct reads. Sure i´ll try this.
mbprado said:
Hi everyone.
Any Idea?
Tks for your help.
    ANSEL = 1
    ANSELH = 0
    TRISA = 1
    TRISB = 0
    PORTB = 0
    LCD_Init()
    LCD_Cmd(_LCD_CLEAR)
    LCD_Chr(1, 16, "V")
    display[1] = "."
end sub
main:
     GlobInit
     while true
     vout:
           delay_ms(50)
     wend
end.
can u post hex code & ckt diagram also ?
Ok. Now, finaly, it's working!
program voltimetro_PH
dim ADCResultV as longword
dim voltageV as string[5]
    'ANSEL = 1
    'ANSELH = 0
    TRISA = %00000011
    LCD_Init(PORTD)
    LCD_Cmd(LCD_CLEAR)
    LCD_Cmd(LCD_CURSOR_OFF)
    LCD_Out(2, 1, "Voltage:")
    LCD_Chr(2, 16, "V")
    display[1] = "."
end sub
main:
     GlobInit
positive:
     while true
           if ADC_READ(0) = 0 then
           goto negative
           end if
           ADCResultV = (ADC_Read(0) * 5000) >> 10
           voltageV[2] = ADCResultV mod 10
           display[4] = voltageV[2] + 48
           LCD_Chr(2,9, " ")
           LCD_Chr(2, 16, "V")
           display[1] = "."
           LCD_Out(2, 10, display)
      wend
negative:
while true
           if ADC_READ(1) = 0 then
           goto positive
           end if
           ADCResult = (ADC_Read(1) * 500) >> 10
           ADCResultV = (ADC_Read(1) * 5000) >> 10
           LCD_Chr(2,9, "-")
wend
end.
adc0 will listen to positive voltages and adc1 will listen to negative voltages inverted by LM741.
Hex file is here, but Im trying to discover how do save the diagram as an image. Sorry.
positive:
     while true
           goto negative
           end if
           LCD_Chr(2,9, " ")
           LCD_Chr(2, 16, "V")
           display[1] = "."
      wend
negative:
while true
           goto positive
           end if
           LCD_Chr(2,9, "-")
wend
You can improve this part to:
while true
     	while ADC_Read(1) = 0
           LCD_Chr(2,9, " ")
           LCD_Chr(2, 16, "V")
           display[1] = "."
	wend
	while ADC_Read(0) = 0
           LCD_Chr(2,9, "-")
	wend
wend
Your code will work fine, the latter just seems more organized.
Hope this helps.
Tahmid.
Hmmm, hi... Im reading the post and Im wondering why to repeat the whole block of code in the conversion of the readed data to ASCII... It would be more efficient and faster to write the common conversion one time and the negative/positive reading in the if then else structure...
PD: Its just a point of view, but perhaps Im wrong... Im a newbie in PICs.
PD2: Wich application did you used to make the schematic????... It could be Proteus??? If its so, you only have to use the option File/Export Graphics and convert your schematic as your wishes.
Have a nice day and hello to all of you.
Just coded this, should work:
program voltmeterplusminus5v
    'ANSEL = 1
    'ANSELH = 0
    TRISA = %00000011
    LCD_Init(PORTD)
    LCD_Cmd(LCD_CLEAR)
    LCD_Chr(2, 16, "V")
    display[1] = "."
end sub
main:
GlobInit
while true
	if ADC_Read(0) = 0 then
		ADCResult = ADC_Read(1)
		LCD_Chr(2, 9, "-")
	end if
	if ADC_Read(1) = 0 then
		ADCResult = ADC_Read(0)
		LCD_Chr(2, 9, " ")
	end if
	ADCResult = (ADCResult * 5000) >> 10
	voltage[0] = ADCResult div 1000
	voltage[1] = (ADCResult div 100) mod 10
	voltage[2] = (ADCResult div 10) mod 10
	voltage[3] = ADCResult mod 10
wend
end
You can try this. As albejanon said, it is more efficient.
Hope this helps.
Tahmid.
    'ANSEL = 1
    'ANSELH = 0
    TRISA = %00000011
    LCD_Init(PORTD)
    LCD_Cmd(LCD_CLEAR)
    LCD_Chr(2, 16, "V")
    display[1] = "."
end sub
main:
     GlobInit
positive:
     while true
           goto negative
           end if
           LCD_Chr(2,9, " ")
           LCD_Chr(2, 16, "V")
           display[1] = "."
      wend
negative:
while true
           goto positive
           end if
           LCD_Chr(2,9, "-")
wend
end.
only 0v > +5v voltimeter not -5 to +5 v/is my req.
    'ANSEL = 1
    'ANSELH = 0
    TRISA = %00000011
    LCD_Init(PORTD)
    LCD_Cmd(LCD_CLEAR)
    LCD_Chr(2, 16, "V")
    display[1] = "."
end sub
main:
GlobInit
while true
		LCD_Chr(2, 9, "-")
	end if
		LCD_Chr(2, 9, " ")
	end if
wend
end
Hope this helps.
Tahmid.
Hi... Yes, thats what I wanted to said... thanks Tahmid.
See this link:
Mr.Cube
hi everybody
i m working on strain gauge project .my out put voltage from -2.5V to +2.5V,which i have scaled from 0V to +5V .
so how can i program it.
like if adc_result=read_adc();
so after this how can i program
thanks &regrads
