16F877A with 7segment sourse code
sonic05
Member level 1
Member level 1
Manila
hi^^
i have a project that using 16F877A with 7segment but i dont how to use PORTA to make a program that number tirigger to nxt 7segment plz help me to make a program that the 7segment counting up by using this microcontroller and PORTA and PORT B
0-59 seconds
plzzz i need ur attention plzzz^^ thank you,,
Re: 16F877A with 7segment
Im sorry I dotn understand what you are asking. Are you saying that you know how to use PORT B and D but not A?
yah,,im sorry for that,, ihave a project that 7segment will count in seconds but i dont know how to use port A,,
Could you be a little more specific. What are you able to do so far? Why are you concerned with PORTA are you able to get it working on PORTB?
yah,,,,and this is the circuit that i want to use but i don't know how i program it,,
SHow me our code so far, are you writing in Asm or C?
sonic05 said:
hi^^
0-59 seconds
What kind of 7 segment display do you have ?
Your schematic is a bit "strange" to me ...
You have to make sure that PORTA is configured as a digital output port :
CMCON = 0x07 ; // turn off comparators
ADCON1 = 0x07 ; // turn off analog inputs
Take a look at this example (asm) :
https://www.mikroe.com/en/books/picbook/7_08chapter.htm
@aj9999 the program that i use is C,,
#include <16F877A.h>
#byte port_a=5
#byte port_d=8
#use delay(clock=4M)
byte CONST ZERO[1]={0x3F};
byte CONST ONE[1]={0x06};
void main(void)
while(1)
output_d(ZERO);
output_low(PIN_A2);
delay_ms(2000);
output_high(PIN_A2);
output_d(ONE);
output_low(PIN_A1);
delay_ms(2000);
output_high(PIN_A1);
tnx 4 ur help^^
Added after 2 minutes:
@hugo the 7segment that i use is only single and common cathode but i don't know how to make a program that the port will become output or input in the 7segment
tnx 4 ur reply^^
As far i understand is that you are confused how to select the appropiate 7-segment for displaying value.Try this may be this will work
int zero=3,one=4;
void main(void)
while(1)
output_d(zero);
output_low(PIN_A2);
output_d(one);
output_low(PIN_A1);
delay_ms(2000);
Also you have to connect a resistor between base of the transistor and microcontroller pin.
help me to correct this program plz
Reactions: sabree
    sabree
When you run any of these programs what does the display do? Does anything turn on? can you turn on and off the segments just by detaching them from the microcontroller and applying power to them?
