T
treez
The below switch says its rated for 10000 operations. But does that mean 10000 operations with the switching happening at the zero crossings, or 10000 ops with switching happening at mains peak?
I assume that the switching refers to when 16A flows at the instant of switch contact make?...ie not instances where in a 16A circuit, massive inrush of 70A (say) flows through the contacts at make time?
Also, the datasheet says it doesn’t refer to inductive switching for the 10000 ops…but in reality , all circuits will have stray inductance, and so we can safely say that the real rating will be nowhere near 10000 ops?
Do you agree that when this switch gets worn out...the contacts will stick together for some time instead of breaking immediately.?
16A switch: (0911 on pg 172)
