Assignment using kiel C51 for 8051
it is possible to 8051 microcontroller to interface multiprocessor communication.
here I post some links with code for you to understand your assignment also find the attachment for application notes.
Atmel Application Note - Multiprocessor Communications with code
For "Intel Application Note- Enhanced Serial Port on the 83C51FA" find the attachment.
hope this helps
regards
bassa
From what I see, is Multi Master and Multi Slave Communication.
I think if you're understand the basic master slave uart communication, it can be done.
please check the following appnote from atmel :
http://www.atmel.com/dyn/resources/prod_documents/doc4346.pdf
Good luck, if you see this appnote you will undrstand, how to set master then turn into slave and vice versa.
Hope this help u
Deny(BODAT'Z)
