donkey41
Full Member level 1
hello there,
can anyone please explain me, what is the actual procedure of THP in a simple double sided pcb ?
according to my understanding, THP needs firstly an electroless hole plating and then electrolytic plating .. correct ?
if the above point is correct then there could be 2 options for THP
1 . first drill the pcb, and do THP, then make traces of the actual circuit and etch the rest of the clad-board.
2. first make traces and etch the board, and then do THP.
in the first option, i have the advantage that every hole is reachable for electroplating process because the board is not etched yet - but if i etch after plating holes, this will etch holes as well ! .. am i right ?
exactly the same, if i make traces and etch the board first, as above in second option, then not every hole is reachable for later electroplating !!??
i may have absolutely missed something here and my understanding could be completely incorrect.
please help me understanding this and solve this "egg-chicken" like problem
i want to make double sided THP'ed pcb at home, that is why i am asking this.
