krish2487
hello all..
before i went ahead with building the boost converter i just wanted to confirm that i am on the right path and that my calculations are correct so far.
Heres the idea
i wanted to build a 36v to 400 v boost converter capable of delivering 100w
the supply voltage is 36 v
here is the schematic i arrived at.
The transformer has primary turns of 6 (swg 21) and secondary turns of 84 (swg 35)
It is a EE28 transformer
i wanted some light on whether the method of isolated feedback i used here is correct or not and whether the values of the components i arrived at for the specfic case are correct.
i have not yet given the values of the gate resistors as i first wanted to confirm that my PWM modulator ckt is acceptable.
attached are the eagle files and the bmp of the same
any help is highly appreciated
Heres the idea
