Sunrom programmer circuit and software for 89c52 and 89c2051
shamikrudra
Full Member level 5
Full Member level 5
Kolkata, India
www.ventor.co.in
Hi
can any body have programmer circuit and software from sunrom for 89C52 and 89C2051.
PLS help me.
I will be very thankfull to you if any one of you can upload ar mail it to me
Thanx.
I have seen the complete package of DIY 89C programmer in this forum. But unable to locate it now..If it is still there and i upload it fior you, that is not allowed here in this forum. If some other friends found it, they may give you the link. If it is not found, i'll upload it here. Cheers
Re: Sunrom programmer circuit and software for 89c52 and 89c
Thanx both of yoy.
pls give me pcb layout and if possible source of that hex file.
and guide me how can i write my own downloader software for PC.
problem with VB is it requires support files i want to create only one exe file.
i heard about delphi can do it, front end creation should easy and good looking.
but i dont know delphi. so what language should I learn?
Thanks again for your kind reply
shamikrudra said:
Thanx both of yoy. pls give me pcb layout and if possible source of that hex file. and guide me how can i write my own downloader software for PC. problem with VB is it requires support files i want to create only one exe file. i heard about delphi can do it, front end creation should easy and good looking.
but i dont know delphi. so what language should I learn? Thanks again for your kind reply
You asked for Programmer circuit with firmware. You got it. But the topic is now pointing somewhere else????????:cry::cry::cry:
finaly got the link may be good for other
or
copy and pest links other wise they wont work
hi every body
finally I finished my programmer.
but it is not working.
I had checked the voltage to all the IC, vcc and gnd pins it shows 4.68
and proload 4.1 saying device offline and with proload5.1 device detect timeout.
firmware is 1001-3456 v44. now what should i check?
how to solv the problem pls help..
check your soldering you might short circuited at some point. i too received the same problem and also "verification failed at address 1".
its perfectly working for me.
regards
kj
@welove8051
thanx for your reply.
I checked all the soldering. I am using ICL232 in place of max232
other things are same as specified. voltage at icl232 is -12v is it ok? i checked at port pins, it also shows -12v aprox. that means board is connected with PC. I programmed
AT89S52 with ISP to store firmware.
i checked with V4.1 and V44 firmware and proload4.1 and proload V5.
but no luck. now frustrated. pls give suggestions. I am using single sided PCB.
Hi
Now Proload detecting the hardware but without chip
if I am placing chips in ZIF socket then proload can't detect the hardware.
where is the problem? pls give me a idea.
Thanks
still not detecting the chip
voltage at chip vcc is 5v. i checked all the soldering and track conectivity.
pls help.
now 20 pin chip is detecting and can be programmed but 40 pin chip in the socket not working showing device detect time out.
still could not locate the problem.
or
The PC software link not working please upload.
Thanks
sadat007
Hi, Thx
Anyone have proper PCB file as the PDF printout size not okay.
Thanks
sadat007
Re: Atmel 89 Series programmer problem
I made this programmer in the year 2006. I tried very hard to get the programmer fully active. It is detecting all chips, reads from it, but can't write to it. Yesterday while reading this thread, I decided to try it again. While trying to program AT89C51, C52, C1051 and C2051, it failed to write, but recognized and read as before. This time I tried with AT89S52, it was miraculously successful. What may be the cause?
I am using firmwareV3 (89xx.hex) with ProLoad21. Vpp is 12.2 volts. Please help to solve the problem.
Thanks,
P55XP
As you have used 89S52, it requires only 5 pins to program, which may be correctly connected, and thus the success. whereas the 89C series requires most of the pins connected to the ZIF socket, and thus the failures. Try looking in to your PCB for small crack, or joins, which may be the cause of the problems. Also look for malfunctionsed components, or which may be accidently assembled in reverse directions.
Cheers
shamikrudra said:
@vaslvsb
I ordered PCB from a local manufacturer in Kolkata.
Did you buy the kit from a Kolkata dealer or you got the PCB design from the net and gave the PCB to be made at a Kolkata PCB shop?
