160 w dc to dc convertor help needed
HI,
You can check at PI for "epr31.pdf"; its a TOP-Switch (TOP249Y)circuit for AC 110V & multi outputs, but has 180W capability
Next one: "rdr189.pdf"; 225W, HiperPLC with PLC810PG.
Than; rdr203.pdf, it has PeakSwitch PKS607YN, generates +/-28V for audio amps, 50W DC & 200W peak power...
I believe you has a simple switcher to select_some TOP-Switch i.e._for 30-55V & a poetregulator with current & voltage controlled output for your 10-48V/0.5-4.0A.
You can minimum 2 of these PI descriptionsadapt for the input switcher & put extra circuits to that for the adjustables
Its not very simple, but has good eficiency % the components are up to date.
Anyway, possible you has a solution i.e. from ST too?
I would search on radio amateurs & solar sites, they has often very similar problems as yours...
K.
