Dear Jestin
Hi
It is simple ! you can use some filters ( passive filters ) and then use ADC . the value of out put of each filter will change instead of different frequencies .
Best Wishes
Goldsmith
is there any way[with out ADC Multiplexing ] to implement Audio spectrum with atmega32 ?
16 channel audio spectrum - circuit diagram atmega32 , two 8x8 led matrix, 2x74hc595 serial shift registers.
F-response 20hz -15khz - ideal [20-20khz]
v-level 0-2.5v
hi ! Jestin you have hex file (atm 32)
you can send me
thaks you
