16 BY 2 LCD display blank
sayalispathak
Newbie
Newbie level 3
Hello,
I am interface 16 by 2 lcd display with TMS320F280025C controller. I have attached a circuit for your reference. supply voltage given to LCD is +5VDC. But the LCD is totally blank. The back light is working fine. Pot used for contrast adjustment is 1k. Any help please.
The schematic is fine but the LCD will not display anything at all if it isn't initialized properly. That is a software issue, you must send it the correct sequence of bytes to configure the on-board processor (probably a HD44780).
Brian.
here is my code.
#include "F28x_Project.h"
#include "common.h"
#include "extern.h"
#include "math.h"
void main(void)
    // Initialize device clock and peripherals
    InitSysCtrl();
    // Initialize GPIO
    InitGpio();
    // Disable CPU interrupts
    DINT;
    // Initialize the PIE control registers to their default state.
    // The default state is all PIE interrupts disabled and flags
    // are cleared.
    InitPieCtrl();
    // Disable CPU interrupts and clear all CPU interrupt flags:
    IER = 0x0000;
    IFR = 0x0000;
    // Initialize the PIE vector table with pointers to the shell Interrupt
    // Service Routines (ISR).
    InitPieVectTable();
   lcd_init();
    EALLOW;
    // Enable PIE interrupt
    PieCtrlRegs.PIEIER1.bit.INTx1 = 1;
    // Enable global Interrupts and higher priority real-time debug events:
    IER |= M_INT1;  // Enable group 1 interrupts
    EINT;           // Enable Global interrupt INTM
    ERTM;           // Enable Global realtime interrupt DBGM
    while(1)
        send_string("Hello, LCD!");
        DELAY_US(1000); // Delay for 1 second
void lcd_init(void)
    GpioCtrlRegs.GPBMUX1.bit.GPIO40 = 0;
    GpioCtrlRegs.GPBDIR.bit.GPIO40 = 1;
    GpioCtrlRegs.GPBMUX1.bit.GPIO41 = 0;
    GpioCtrlRegs.GPBDIR.bit.GPIO41 = 1;
    GpioCtrlRegs.GPAMUX2.bit.GPIO23 = 0;
    GpioCtrlRegs.GPADIR.bit.GPIO23 = 1;
    GpioCtrlRegs.GPAMUX2.bit.GPIO22 = 0;
    GpioCtrlRegs.GPADIR.bit.GPIO22 = 1;
    // Configure LCD control pins as outputs
    GpioCtrlRegs.GPAMUX1.bit.GPIO1 = 0;   // RS
    GpioCtrlRegs.GPAMUX1.bit.GPIO0 = 0;   // EN
    GpioCtrlRegs.GPADIR.bit.GPIO1 = 1;    // RS
    GpioCtrlRegs.GPADIR.bit.GPIO0 = 1;    // EN
    DELAY_US(15000);      // 15000us...0.015 seconds
    DELAY_US(4100);       // 4100us
    DELAY_US(100);
    send_command(0x33);       // 4 bit mode
    send_command(0x32);       // 4 bit mode
    DELAY_US(4100);
    send_command(0x28);       // 4 bit mode
    DELAY_US(40);
    send_command(0x0E);       // display on cursor on
    DELAY_US(40);
    send_command(0x01);       // clear the screen
    DELAY_US(40);
    send_command(0x06);       // increment cursor
    DELAY_US(1640);
    send_command(0x80);       // row 1 column 1
    DELAY_US(4100);
void send_command(unsigned char cmd)
    GpioDataRegs.GPACLEAR.bit.GPIO1 = 1; // RS = 0 (command mode)
    GpioDataRegs.GPASET.bit.GPIO0 = 1;  // EN = 1 (enable high)
    GpioDataRegs.GPBDAT.bit.GPIO40 = (cmd >> 4) & 0x01;
    GpioDataRegs.GPADAT.bit.GPIO23 = (cmd >> 5) & 0x01;
    GpioDataRegs.GPBDAT.bit.GPIO41 = (cmd >> 6) & 0x01;
    GpioDataRegs.GPADAT.bit.GPIO22 = (cmd >> 7) & 0x01;
    GpioDataRegs.GPACLEAR.bit.GPIO0 = 1; // EN = 0 (enable low)
    DELAY_US(2000);   // Delay required for command execution
    GpioDataRegs.GPBDAT.bit.GPIO40 = cmd & 0x01;
    GpioDataRegs.GPADAT.bit.GPIO23 = (cmd >> 1) & 0x01;
    GpioDataRegs.GPBDAT.bit.GPIO41 = (cmd >> 2) & 0x01;
    GpioDataRegs.GPADAT.bit.GPIO22 = (cmd >> 3) & 0x01;
    DELAY_US(2000);
void send_string(char *s)
    while(*s)
        send_data(*s);
        s++;
void send_data(unsigned char data)
    GpioDataRegs.GPASET.bit.GPIO1 = 1;     // RS = 1 (Data mode)
    GpioDataRegs.GPBDAT.bit.GPIO40 = (data >> 4) & 0x01;
    GpioDataRegs.GPADAT.bit.GPIO23 = (data >> 5) & 0x01;
    GpioDataRegs.GPBDAT.bit.GPIO41 = (data >> 6) & 0x01;
    GpioDataRegs.GPADAT.bit.GPIO22 = (data >> 7) & 0x01;
    GpioDataRegs.GPBDAT.bit.GPIO40 = data & 0x01;
    GpioDataRegs.GPADAT.bit.GPIO23 = (data >> 1) & 0x01;
    GpioDataRegs.GPBDAT.bit.GPIO41 = (data >> 2) & 0x01;
    GpioDataRegs.GPADAT.bit.GPIO22 = (data >> 3) & 0x01;
    DELAY_US(2000);
please check and let me know.
[code tags added by moderator]
If you want to show any text on the LCD screen, you have to ground the R/W pin too. Also, you may need to vary the variable resistor connected to V0 pin. Sometimes texts appear after you adjust the brightness with this variable resistor.
What are you using as a 'delay' function - if you are writing your own 'busy wait' style function then the chances are it is not working.
As is often the case. the problem may be in the code you don't show.
Susan
LaTeX Commands Quick-Menu:
